So I picked up my air pump today... I found out that I had 0 PSI in my shocks! No wonder the suspension felt so horrible. Upped it to 20 PSI, feels much better. I even rode 2 up with 0 PSI!
Bought my bike last year and just checked my pressure and found out it was 9psi. Think I'm going to up that to maybe 20 psi. It will bottom out at 9psi on large bumps. I mostly ride 1 up my weight is 190. I think this should help. Will adding air pressure change the rear ride height?
I didn't buy one...I just to the dealer and borrow the one they have in the display window...use it and then give it back..I weigh 150 so I only need about 9psi in the shocks...
When you sit on your bike the suspension sags a bit. If you add air it may not sag quite as much. I doubt if you will noticed any change.
