my heated grips stopped working. i think they have been on the bike since it was new. i think they are part #56512-02a.
any idea why they stopped working? or
what would be a good replacement for these?
thanks,vinnie
i like the fact that they molded(or melted) to my hand. they were always comfortable. now that they are worn out. i need to get new ones. i think im the only person that had heated grips for years?
I had the same problem. On throttle grip take off end cap there is a pronged plug in, it has probably came loose. plug it back in, should take care of it.
The only place to start is at the fuse. Make sure that there is power to it and then that the fuse is not blown. Then move up to the switch and see if there is power to it, and if you turn it on power from it. If still good the actual heater loops have failed and need to be replaced. If you do not have the tools to do all the checks, find a pro. Personally I hate electrical stuff.
