How many miles to Dyno
I made an appointment four weeks ago to get my bike on the dyno. and figured to have around 400 miles till then.However the weather here will not give up and now i have six days left and only 100 miles on a new 103 build with cams and head work.If im lucky i will get another hundred before tuesday,as im writing this it's snowing outside. is that enough break in for forged pistons and hasting rings?
Location: Beverly Hills, Fl. Swimmin pools. Movie stars
Most of the ring seating will occur in less than 50 miles; the trick is IMHO to run it a bit on the hard side keeping pressure on the rings (accelerate/decelerate), drop the oil at 50-60 miles and ride it like you normally do. I had mine on the dyno at right about 100 miles, that was 9k miles ago and it runs fine but to each their own, good luck
