ABS Light Stays On
ABS Light Stays On
Each time I remove my front tire for some reason and then reinstall it, the ABS light stays on. I took my SG to the dealer to fix it the last time. I was wondering if anyone can tell me what needs to be done to fix this issue instead of taking to the dealer again. Thanks
I will admit I looked foolish but I had the same problem and it was I had the tire on backwards. The sensor is on the tan greenish wheel bearing side. The tire tread on the front does not go in the same direction as the back! It looks like a directional tread but the front goes the opposite direction as the rear tire.
1+ on this. I had to replace my fender when I hit a deer and put the wheel on backwards because of the tire tread pattern. ABS light came on and rotors became very hot til I figured it out. Turned the wheel around and the light went out. CAN YOU SAY STUPID?
I think what is stupid is if you look at the tread pattern, on backwards makes more sense. On the rear, the grooves take the water from center out the sides. They turn it around on the front and the pattern pushes the water to the center of the tire. Hydroplane!
