Screamin' EagleŽ Hydraulic Cam Chain T
Old 03-29-2011 | 11:48 PM
bowa18's Avatar
bowa18
Default Screamin' EagleŽ Hydraulic Cam Chain T
I've searched this subject and read and read and read...information overload!!! Anyways,
My bud has an 2001 Roadking classic FI and we're going to swap out his old style cam tensioners with the SE hydraulic upgrade kit. Would anyone have a complete list of what parts we're going to need besides what comes in the kit? Also, does anyone have a link to any websites that shows the process of doing the upgrade (pics are always nice!). Thanks for any pointers and info, Larry
Old 03-30-2011 | 02:12 AM
emwolb's Avatar
emwolb
just go to the nearest harley shop and they'll be able to give you a list of what you'll need. that would be the simplest way, i'd think.
Old 03-30-2011 | 05:13 AM
AmphibSailor's Avatar
AmphibSailor
Talking Conversion Parts List
Easy enough:
26037-06 Oil pump assembly
25355-06 Cam support plate assembly
4741 Support plate screws
11461 Retaining ring (front cam)
25683-06 Inner roller chain
39969-06 Inner chain tensioner
25675-06 Outer roller chain
39968-06 Outer chain tensiomer
25729-06 Spacer (.100 for cam alignment; use as required)
25731-06 Spacer (.110 for cam alignment; use as required)
25734-06 Spacer (.120 for cam alignment; use as required)
25736-06 Spacer (.130 for cam alignment; use as required)
25737-06 Spacer (.140 for cam alignment; use as required)
25738-06 Spacer (.150 for cam alignment; use as required)
25673-06 Crankshaft sprocket (17 teeth)
25728-06 Stock rear cam sprocket (34 teeth) (Only used with 2002 and later engines)
216015 (Andrews #) Andrews rear cam sprocket (34 teeth) (Must be used with 99, '00, '01 engines)
Plus the conversion cam....This information is found on the on the Andrews web site.
Old 03-30-2011 | 05:28 AM
akroguy's Avatar
akroguy
It's a good idea to replace the HD inner cam bearings with Torrington B-148 bearings while you're in there. These can be found at your local bearing/industrial supply shop or ordered online. A blind bearing puller is needed and can be rented at Autozone or, a puller kit is pretty cheap from Harbor Freight. Also, a search here for "Herko" will yield a supplier of a complete kit of everything. Many of these have been used to do this job. I pieced together the parts kits for mine, and ended up with some duplicates and some stuff that didn't apply to my model year bike.
And....while you're in there (you really didn't think this was the end of it, did you? hehe) sh*tcan the weak *** stock cams! Get some Andrews 21 or 26, or Woods or SE....anything is better than the stock cams. The performance improvement is noticeable. Then, you'll need a fuel controller or FI download....then...
Ok....I'll stop now.
Old 03-30-2011 | 09:18 AM
dawg's Avatar
dawg
17045-99D cam service gasket kit
25285-08 cam spacer kit
24017-10 SE inner cam bearings
They say you need a 25533-99A retention kit as extra, but the last two I've done had them included in the kit so I don't know why they say that.
EarlB
Engine Mechanical Topics
08-07-2018 09:19 AM
jpekarek
04-23-2017 07:51 PM
Redbeard719
02-16-2013 08:30 PM
JamesT
Exhaust System Topics
25
03-19-2012 04:48 PM
rags
10-31-2009 02:34 AM
Quick Reply: Screamin' EagleŽ Hydraulic Cam Chain T
