This is my third attempt at fabricating a bracket to mount 59 Caddie tail lights as turn signal / running lights on my 07 FLHP. I think its going to work. I've attached a couple of pictures of them mounted in rough form. I'm going to ride to work with them on the bike to see if I still like them.
Looks good. How do you like having your license plate mounted under the saddlebag? Do you have any issues with clearance? I've been considering this for some time, but my bike is lower quite a bit in the back and I worry about scraping.
Thanks, The license plate has never scrapped yet. I drilled a couple of holes in an old style license plate bracket off of a hinged FL fender. Then I added a backing plate to support the license plate and then bolted it thru the rear rubber exhaust mount.
