Hawg wired amp settings
Old 03-27-2011, 10:36 AM
3itodd's Avatar
3itodd
3itodd is offline
Default Hawg wired amp settings
Hello, I have the hawg wired double shot system in my street glide.. Just curious if anyone has the system and what you have your amp set at? the frequancy 50-250 hz ? low,full,high pass filter? and the gain?
Thanks Alot
Old 03-27-2011, 11:16 AM
tj316's Avatar
tj316
tj316 is offline
I had one and set it at their recommended settings and left it, it always sounded great
Old 03-27-2011, 12:16 PM
10-4 10-4's Avatar
10-4 10-4
10-4 10-4 is offline
do you guys have any pics of the install?? I just purshased the PSC3004 system and wouldlike to aviod any mistake if possible?? thanks ( i purshased the Paul Yaffe system)
Old 03-27-2011, 12:27 PM
3itodd's Avatar
3itodd
3itodd is offline
I dont have the instructions to know the recomeneded settings ...
Old 03-27-2011, 01:44 PM
Harleypingman's Avatar
Harleypingman
Harleypingman is offline
HW has the installation instructions on their website. If you need more information, just call them.
Carl
Old 03-27-2011, 02:16 PM
10-4 10-4's Avatar
10-4 10-4
Brova a pic is worth more then writing ...LOLOLOLL
Old 03-27-2011, 02:18 PM
davidw221's Avatar
davidw221
davidw221 is offline
Has anyone put in a oil Temperature gauge into their fairing, and replacing the worthless air temperature gauge?
How much did it cost?
Is it worth it?
Old 03-27-2011, 02:35 PM
MoChrome's Avatar
MoChrome
MoChrome is offline
[quote=3itodd;8105035]Hello, I have the hawg wired double shot system in my street glide.. Just curious if anyone has the system and what you have your amp set at? the frequancy 50-250 hz ? low,full,high pass filter? and the gain?
Thanks Alot[/quote
After meessing around with mine a little, I found their recommended settings to be best (duh).
Set the filter setting to HIGH
Turn the Frequency and Gain all the way counterclockwise and then back clockwise to the 3 - 4 o'clock position.
Give that a try and see what you think.
Old 03-27-2011, 08:02 PM
neano62's Avatar
neano62
neano62 is offline
With the Dblsht. 5.25" speakers,...definatly put gain at 5 oclock. Put the frequency all the way up.
I hate to tell you guys tho, that Hawg-Wired is cumin out w/a new 200 watt amp and 6.5" speakers. They will b selling this as a pkge. deal like the dblsht. pkge., and they are cumin out w/a 400 watt 4 - channel amp to!!!
6.5" speakers are for sale 'NOW' amp will follow in a week or 2.
Call Frank @ DragosBikeWorks he is a sponsor here and will give you the best $!
Old 03-27-2011, 10:35 PM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
Neggy ZRXOA 5248 is offline
Is it worth it?
McEwan makes one, runs around a C note iirc, Wally's sells them
Quick Reply: Hawg wired amp settings
