Installing SE compensator kit w/pics
#612
I did make a locking bar....wasn't too difficult.
#613
I do have this for sale if someone needs. Thanks.
Harley Compensator Maxlok MX/T6 adhesive + extra nozzles
#614
Installing SE compensator kit with pics
Nice document! I no longer need it (did my install in May) but converted yours to PDF in the event someone doesn't have Word etc (my Word version is older and some docs won't open in it!). Also easier to view PDF on a phone. Nice document!
#615
Found most threads on here with 'pics' are now defunct since Photobucket disallowed their sharing. Too bad, it destroyed a lot of useful threads.
bshapiro (06-26-2018)
#616
I know this is an old thread But I just found it last week. THANK YOU to the guy who started it and all who added to it. I had a hard start when hot problem for a long time. I just replaced my compensator sprocket on my 08 Ultra Classic I used the info on here for the parts and the place to buy the epoxy. I took off the outer cover filed down the inner primary and easily removed the old compensator WITHOUT having to remove the inner primary and without even touching the clutch. I used a block of wood to keep the compensator from turning when I removed the nut from the old sprocket and when I tightened the nut on the new one. Really a pretty easy job that only took less then 3 hours . It starts perfectly now when hot. Problem solved Thanks again for all the Help
bshapiro (06-27-2018)
#617
It was a good experience....as its a precursor to replacing ones belt- similar work pulling the entire primary. Mine starts ok 90% of the time now, still better to let it sit a bit when hot from riding else it has that haaaaang as due to compression, letting it bleed off seems to help.
#618
Just throwing this out there for someone down the road....
I replaced the HD OEM tensioner with the Southern Oregon Hot Bikes HB125-07 Hydraulic Automatic Primary Chain Tensioner.
Install requires blue loctite btw (I called to ask, wasn't sure red or blue)....and the bolt torque is in the video.
#620
