Dyno Results 07 SG 103 Stage 2 SE255
OK, since nobody has mentioned it yet, I guess I'll go ahead and ask. Why did the tuner tune WOT at approx 14:1 A/F ratio instead of going for 13:1 ? I was always under the impression that the fuel injected bikes liked 13:1 AFR for best TQ/HP. Isn't 14:1 a little lean? Good numbers for sure, but I think there's some more HP/TQ to be had.
how did you gather that info... I gained more then that. if you are basing your info on the dyno chart ok...
But the two pulls that are shown on the chart are from several pulls not from the original stock pull. Hope that clarifies.
A stock 96 street glide has roughly 78hp and 92lbs...
I think my numbers 86hp to 102.5lbs is a great up grade and well worth the money considering I only payed 450 for a new 103 stage 2 including se 255 cams...
Money well spent for me.
Other then thatI think the tune came out just fine...bike runs real good now
