SG Tour Pak / Antenna
For any SG owner who installed a King Tour Pak on their bike and is using the supplied antenna mount that is mounted on the back of the Pak, did you use the original cable/connector that went to the saddlebag mount at the rear of the bike?
And if you did, I'm assuming it's long enough to be routed into the Pak and hooked up to the male connector inside the Pak.
Helping a friend order parts and install the Pak on his 2010 SG and want to make sure I have all the parts ordered before starting the install.
So, assuming the cables are the same length, I should be good.....But we know what happens when we assume!!!
