First oil change, hints/tips welcome
Getting my delivery of Redline synthetic and shockproof heavy tomorrow. Wondering what tips you guys may have for eliminating any oil spilling during the filter removal. I've read everything from 2-liter bottles with a cutout to aluminum foil placed under the filter.
I guess I could just use a shop rag as I have been planning but will listen to any pointers offerred. I know I can just 'suck it up' regarding spilled oil but if I can avoid having to use brake/parts cleaner to remove unwanted spillage I figure I would be ahead of the game.
RE: First oil change, hints/tips welcome
Get the HD Oil Filter removal tool.
Get the engine up to operating temperature before you start. Oil drains faster/better that way.
Use the funnel tricks listed above - OR - go to Dennis Kirk and get the preformed funnel for $15. I plan on doing enough of my own oil changes to easily justify that one. It works great and will keep the oil off your front mount.
Spin the filter on hand tight. Don't forget to smear a little oil around the rubber gasket before you put it on.
Get some beer before you start. One of the classic combos: Cold Beer and changing your own oil on your HD!
ORIGINAL: dionne51
Figure out about how many miles you plan to put on your scoot in a year and purchase enough oil filters to accomodate the amount of oil changes you will be doing (to include the final winterization one). You can get these from Zanotti's cheaper than you can at your local dealer. You can also purchase the same amount of oil plug o-rings or you can cross match the first one you buy and buy a box of 100 cheaper than HD sells them. I noticed when I bought my scoot that the service dept had used teflon tape on all the drain plugs so I continue to do so along with changing the o-rings at each service interval whether it needs it or not (cheap insurance) My scoot says it takes 4 qts of oil. I use 3.5 quarts initially and then check it after my first ride after the oil change and I then add as necessary. I generally change all three holes at the same time and check the primary chain slack and clutch adjustment while there. I do the soda bottle trick with the oil filter. Some folks here fill their oil filter prior to installing and some don't (I have a poll on this in the oil section) Don't know how close you are to Manchester, NH but if you get up that way R&R Cycles is in Manchester and they are one of the best indy shops in the area (they are frequently featured in American Iron) They sell Redline oil which would save you shipping. Hope some or all of this helped.
