"Flat Tire" Feeling on 2009 and later Touring Bikes
Old 03-22-2011 | 06:20 PM
Faast Ed's Avatar
Faast Ed
Originally Posted by JimmyDee
I have experenced that "flat tire" feeling on my '08 Streetglide. It doesn't just happen in the curves it can happen on the straight away. I am working with the very helpful people at True-Track on getting my problem solved.
My Question: Is this problem isolated only to pre-2009 Harleys or has anyone experenced this on later models
Have a great evening...
Jim
Tru track may resolve your situation, but theoretically it will be masking the symptoms. Solve the problem and you won't need to mask the symptoms.
Old 03-22-2011 | 06:27 PM
smitty901's Avatar
smitty901
Let me guess in a few days we will read about someone coming up with a bolt on cure for the 2009 new fame wobble get your now on 399.00 plus shipping, installs in minutes.
Old 03-22-2011 | 06:57 PM
JimmyDee's Avatar
JimmyDee
''I'm a bit confused...
Title says 2009 and later...Then you mention your 2008...then you want to know if it's isolated to pre-2009's
So which is it? If you are asking about 2009 and later it could be the cupping issue that Harley issued a bulletin for.''
The title says 2009 and later....I have a 2008 SG and I was thinking if this can not be worked out on my '08 I would look at the newer frame style. Just did not want to jump from the frying pan to the fire.
Old 03-22-2011 | 06:59 PM
JimmyDee's Avatar
JimmyDee
Maybe / maybe not - There might be a better way to build a mouse trap.
Old 03-22-2011 | 07:18 PM
harleyman1340's Avatar
harleyman1340
'09 Ultra here, I have experienced the "flat tire" feel about a half dozen times in the 6500 miles I've owned the bike. I experieced the feeling in the front end and very low speed, probably less the 10mph.
Old 03-22-2011 | 07:49 PM
kenfm2000's Avatar
kenfm2000
You say 10lbs of air in the tire? What kind of tire is that? I would say if are running 10lbs of air in the tires that is where your flat tire feeling is coming from.
Old 03-22-2011 | 08:15 PM
tommyj's Avatar
tommyj
Default Flat tire feel 2009+
I have the squirmy feeling in my 09 Ultra but only after changing from the 407F to the 408F. I've tried several air pressures, with no difference. When I return to Tennessee next week I'm going to ask for a remount, I checked the wheel weights and there are two just adjacent to the air valve, a strange place for them. I thought the heavy part of the tire went by the valve???? or do I have that screwed up. The squirmy feeling is noticeable on decel but most noticeable from 50 thru 30mph.
Old 03-22-2011 | 08:26 PM
Teardrop's Avatar
Teardrop
i have never felt the flat tire feeling on my 2010UC.
07yellowglide's Avatar
07yellowglide
Default crazy weights
Yes 10lbs.
Installing a True-Track to see if it helps.
Might have to change tires/wheels to get rid of the vibration, I think the front wheel has too many wheel weights (7). Might be trying to get an egg to roll like a circle. Don't know at this point I am just grasping...
I would say,,,and I'm no expert......if you have 7 weights on a rim..then you have a shi()**t tire............that's insane...............
also zi truely hope you are kidding when you said 10 lbs of air.....should be at least 36 lbs up front
Old 03-22-2011 | 08:30 PM
themensh's Avatar
themensh
I run more than ten PSI in my shocks.......
Quick Reply: "Flat Tire" Feeling on 2009 and later Touring Bikes
