SG - Wind Deflection Options
Thanks for the heads up, I found them on ebay.
A good windshield will help a lot. The freedom wings help a little, the triple tree deflector helps a little, the fork deflectors help a little. None of those will stop the air from coming up from under the fairing and rushing up into your face. I'll tell you why. Feel where the air is coming from, put your hand down and follow it. You will find it is flowing from about six inches above and about six inches below the top bar of your crash bar, from the frame all the way to the outside edge. There is nothing on the market that I was able to find that will block that air, except: These come close... Fairing lowers and Baker Built had some that came close, but they interfered with the foot controls too much.
You will need to make something of your own. Some plastic, the type of your choice, about 11 or 12" square with rounded corners, fancy them up anyway you want and attach them with P clamps (black or chrome, about $20 each). One P clamp in the center of each will hold them nicely (I used large washers too). Mine go from just short of the frame to just short of the out side edge of the crash bar. About six inches up and down from the crash bar. Not so high as to hit the fairing when making a sharp turn.
They are different than anything else I see on other bikes, but they do not look bad to me and they work very well. I get a slight breeze all around me, enough to help cool me off on a hot day, and some wind comes up behind me and hits me in the back. Pretty calm where I sit, a little breeze, very nice.
I recently added the fairing lowers to my 2010 SG and after a ride today in really strong winds, I must say they really improved the "wind management" problems that I had. Prior to the fairing lowers, with a 6.5" Klock Werks, my glasses vibrated to the point of making it difficult to see clearly. I could hold my hand beside the gas tank and the wind blast would support the weight of my arm...with the lower fairings, that is gone...or at least moved to a place that it doesn't impact me directly. It's a pricey accessory but worth it. Not to mention the improvement to engine temps that the lower fairings have improved upon. I've read extensively on various forums on the effects of the lowers and am now a believer.
![](http://i587.photobucket.com/albums/ss313/taco130130/IMG_0093.jpg)
i'm using a 10" long ride shield and the fork air baffle which bolts on to the lower triple tree and the side wings that are adjustable. i'm very comfortable riding my streetglide. i can smoke at 70 mph without a problem. this combination makes for a very nice pocket of still air, sure the air is still there, but it's not annoying at all with the above mods.
Not true. The fork deflectors that I bought on Ebay have a hole for the turn signals. Took about 5 min to install. They absolutely kill all buffeting from my waist up to my chin. My Clearview 8" recurve windshield takes care of the rest. It was one of the best mods I have purchased to date. Wouldn't trade them for anything.
It sounds like you guys have found an acceptable solution. My cigarettes look like gnarled pieces of paper after 2 minutes.
![Smile](https://www.hdforums.com/forum/images/smilies/smile.gif)
The deflectors in the link are not for a StreetGlide...I couldn't find any in his store. You could email him and ask him when he's getting more deflectors for the FLHX.
http://cgi.ebay.com/ebaymotors/HARLE...s#ht_500wt_956
