Extreme heat issue, exhaust pipe burned off, completely severed
*sigh*
I have a 2000 Ultra, stock 88 still in it. I have thunder header slip ons, and I recently upgraded to a stage 1 Air Kit during a recent oil change because it was discovered that there was a crack in the stock plastic piece that goies into the motor and it was spraying oil.
A few months ago I noticed the rear of the pipe starting to brown and it became progressively worse. I thought it was because I was just riding too hard.
The past few weeks I had been hearing this noise that sounded like some sort of binding at the point when i give it a little throttle just above idle.
Saturday i discovered that the pipe was completely severed at the point where the two pipes come together join near the footboard.
Before I purchase another set of pipes and eventually ruin these also, can someone explain why this might be happening?
It seems like anytime the air intake is changed on these bikes that the fuel management will also need addressing....carbed or fuel injected......especially with aftermarket exhaust being used in conjunction with an air intake upgrade.....this will help overcome lean issues....
Makes sence. Is that something that the dealership should have adjusted when they upgraded the stage 1?
But before I purchase it, I feel as though I need to address the issue that screwed it up in the first place.
Never heard D&D or Rienhart's installed before so I have no opinion but, I need something stronger due to my riding style.
