Radio quit
Old 03-20-2011 | 08:45 PM
1st 96 ultra's Avatar
1st 96 ultra
Default Radio quit
Was out playing with the bikes in the garage and thought I would listen to my radio and it will not come on, just like somE more post on here it light up and seems to work but no sound , the only thing I have noticed is a small set of headphones on the display , can not find anything in the book about them, any ideas
Old 03-20-2011 | 08:55 PM
BadPiggy's Avatar
BadPiggy
The headphone symbol means you have it muted.
One of the switches on your switch housing where your ignition switch is located has been flipped.
Go flip it back.
Old 03-21-2011 | 04:27 AM
1st 96 ultra
Go flip it back.
thought that was it and have fliped every thing I can find and all that gets fliped off is me
Old 03-21-2011 | 05:10 AM
geezer glide 56's Avatar
geezer glide 56
What about the spkr rocker switch on the console?
Old 03-22-2011 | 06:41 AM
BadPiggy's Avatar
BadPiggy
I believe the speaker toggle is a 3 position switch.
Make sure you tried all 3 positions.
Old 03-22-2011 | 07:04 AM
JohnnyC's Avatar
JohnnyC
Do you have the manual for your radio?
Headphone symbol should be a sign that the radio speakers have been muted and the headphone jack activated. Not knowing this particular radio I'd say there's a switch or menu on the radio to put it back in speaker mode.
Check the radio's manual for the correct answer.
Old 04-05-2011 | 06:39 PM
1st 96 ultra
update , well finally got nice enough to ride so I called the dealer to see if they could get my bike in if I brought it up [ have already talked to them about the problem ] and they told me they could so I took off fo the 30 mile trip , radio onall the way but no sound , got to the dealer they weeled it in the back and you can guess what happened next , turned the switch on and radio worked fine ,they did reboot it while I was there, so they wrote it up , no charge , and off I went , and the fun now starts , half way home the sound starts going on and off ,the display goesfrom speaker to mute and by the time I get home no sound , so we will have to keep playing the game till they can diagnose it , which I do understand cause I deal with new equipment and the warrenty process can be a bit...., will update on the fix
Old 04-06-2011 | 01:28 AM
Johan96's Avatar
Johan96
Do you get sound when you use the cd player?
Old 04-06-2011 | 04:16 AM
1st 96 ultra
no tryed a cd and no sound but do not have headsets so I do not know if they work
Old 04-06-2011 | 05:11 AM
shortride's Avatar
shortride
I've been having the same problem. I had the 3-way switch replaced under warranty. That corrected the problem.
When it stopped working, I could flip the speaker switch back and forth a few times and it would work for a while.
Quick Reply: Radio quit
