Dynojet PCV and Altitude?
I had a PCV went from here to Ohio through the NC mountains, every time I would stop for fuel the bike would surge at Idle. By the time I got to Ohio it was cutting off at idle. Went to the HD dealer and had them put some plugs in. Said the old ones were fouled out. Came back and did not have the exact same issue but the check engine light came on. So i ripped it off my bike once I got back and never looked back. Wondering since this device is a plus minus module even tho the computer is adjusting the afr using the MAF being that the PCV is tricking the signal it would still run richer than it should at the higher altitudes. I thought the ECM logic used the o2 sensors as a fail safe way to check the rich/lean condition of the exhaust and then refers to the VE, timing, and MAF sensors to come up with a solution.
No problems with our email, however we are currently encountering an extremely high volume and while we are trying to answer most of them within 24 hours it should be no longer than 72 hours before you recieve a response. For immediate info and support you can contact us from 9:00-5:00 CST at 877-729-4754
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Both ways are effective for tuning. It sounds like there was some sort of problem somewhere as there is nothing adaptive on the PC-V and unless there is an issue it will not cause and engine light. An easy answer on how the system works would be that the ECM looks at MAP, IAT, ET, CP and TPS and uses the lookup tables in the calibration (VE, Spark, etc) to "command" the fuel delivery/spark timing, then on the control side of things if the AFR/Lambda table is set up for closed loop (14.6-15:0 on AFR bikes .977-1.03 on Lambda based cals) the O2 integrator uses feedback to maintain what is written in the calibration and later adaptive block learn. The system does not have a MAF sensor. As far as the PC-V goes it does not trick the system it uses injector drivers and actually runs the injectors, it looks at the current injector pulse and uses it for a baseline.
OLD 96
01-07-2018 10:50 PM
Jeffinburlington
37
12-29-2014 11:02 PM
Lone wolf lo 10
09-19-2012 09:16 AM
