extension cable measures 13 apehanger "street glide 08
hello guys, in anticipation of the new handlebar mount 13 "Cyclesmith, I ask you how many cm should be lengthened the wires (I think there is a connector for each side to change).
The cable brake and clutch to what should be longer
I ride a 2008 street glide i.e. 1584cc
Has anyone done this kind of change?
thank you very much
Lory
lorenzo.trulli@libero.it
thank you very much
Lory
I had 13" Cyclesmith on my 05 EGC and used +6 on cables and brake line. Did not need to extend the wires, you should have plenty. You may need to reroute your plugs under the radio, but should work fine. Good luck.
Take pics as you go and plenty of notes and draw diagrams of wires and colors to there location. They will be priceless later when your putting all back together.
