Radio Shack - Alarm Siren Install - 2011 RGC
Old 03-01-2012 | 10:03 PM
Bagger71's Avatar
Bagger71
Wachuco,
Thanks for the great tip! I picked up the parts at Radio Shack and installed mine tonight. Works perfect. Only thing I did differently was to use my dremel to make a hole through the back side of the dummy socket so I could push the connector back into place with no visble wires, shrink tubed each wire then siliconed the hole.
Thanks again for the inesxpensive alternative to Harleys $100 siren!
  #52
Old 03-01-2012 | 10:05 PM
Bagger71's Avatar
Bagger71
Somehow multiple posted and can't get it deleted.
  #53
Old 03-23-2012 | 03:24 PM
Paul On The Run's Avatar
Paul On The Run
subbed doing this this weekend.
  #54
Old 03-23-2012 | 04:07 PM
103megawatt's Avatar
103megawatt
Nice writeup and pics, thanks.
  #55
Old 03-25-2012 | 08:53 PM
Paul On The Run
So I just installed mine and like the rest have said, it was way too easy and only took about 5 minutes......in my case. Thanks for the write info.
  #56
Old 03-25-2012 | 09:27 PM
Bocifus's Avatar
Bocifus
Anybody know if this will work on an '06 Deluxe?
  #57
Old 03-25-2012 | 09:31 PM
spacewalker's Avatar
spacewalker
3rd Gear
I just did 2 installs and everything works perfectly.Nice write up!
  #58
Old 04-24-2012 | 10:56 AM
Pagan48's Avatar
Pagan48
Did the install this a.m. Works great. One thing I seem to have that I don't remember seeing is that I get a single chirp when I turn the ignition on and when the system sets when I turn it off. Anybody else have this?
  #59
Old 04-24-2012 | 05:49 PM
Chunker's Avatar
Chunker
Yep, same here. Don't go out and move the bike without the FOB handy or it will scream at you until you go get it. Loud in an enclosed garage.
  #60
Old 04-24-2012 | 05:58 PM
CRZYLGZZ's Avatar
CRZYLGZZ
Wait..I understand the need for the male pins , connection etc..etc...but why a 9 pin connector. Why not buy the applicable molex ( I think its called ) connector from HD. It's like 6 dollars then run your wireing and wallah..why buy a 9 pin for a 3 pin connection. I .probably sound like I belong on a short yellow bus with a larger helmet , but my connector doesn't seem to need a 9 point set up
Quick Reply: Radio Shack - Alarm Siren Install - 2011 RGC
