I just ordered this receptacle today, it is an entire kit with male pins and wire seals included. Hopefully it will be here sometime next week. I am not sure how well it will work, or if it is a better fit than the one mentioned at the beginning of this thread, but form the looks it appears to be the correct connector....I will pass on any info once I recieve and try it out.
Ps. According to the service manual, the existing plug is a "3 Place Delphi GT 150 Sealed" for those wishing to explore it further.
Just curious if you ever received the Delphi GT 150 components and were they correct? Just brought my wife a '12 XL883L Superlow and thought I'd add the siren to her system at the same time I add to my '06 RKC.
Am I correct in understanding that the factory HD siren has a battery back up? I was thinking by doing it this way with the RS siren all someone would have to do is pull the side cover off and pull the main fuse-
You are correct. If that is an issue, best to go with the factory unit.
If someone was going to go to the trouble to remove the side cover and pull the main fuse, then they could just unhook the connector for the siren which is a few inches forward of the fuse.
Just curious if you ever received the Delphi GT 150 components and were they correct? Just brought my wife a '12 XL883L Superlow and thought I'd add the siren to her system at the same time I add to my '06 RKC.a
BTW - This forum rocks.
Sorry, I forgot to come back and give an update. The plug I received is the correct configuration but it is much bigger in size than the one Harley is using on their end...unfortunately it will not work.
