Radio Shack - Alarm Siren Install - 2011 RGC
Old 06-05-2011 | 12:16 PM
Jack Straw's Avatar
Jack Straw
Did the install yesterday. Works great. Thanks wachuko!!
Pic here, page 2.
https://www.hdforums.com/forum/touri...art-2-a-2.html
  #32
Old 06-05-2011 | 07:52 PM
JollyRogers's Avatar
JollyRogers
Picked stuff at RS today and just installed it a few minutes ago. Asked my son to go move my bike... he gotta a little surprise Thanks for posting up the info.
  #33
Old 06-20-2011 | 01:52 PM
SE120RG's Avatar
SE120RG
just finished this little project. works as described, great mod for less than the cost of a 6 pack
  #34
Old 06-27-2011 | 08:24 PM
SE120RG's Avatar
SE120RG
Originally Posted by dawg
Here is the link to the 3 place metri-pack connector needed that I posted on the other thread in the other forum if you want to make it look factory without having to splice and run it through the dummy connector. Have to buy pack of 10 but I'm sure you could split them/sell them with others doing this mod.
well that was a waste of $22. I bought the min 10 plus shipping thinking others here on the forum could use some. that connector is not even close to being the correct one.
  #35
Old 07-06-2011 | 10:08 AM
Das_Fatboy's Avatar
Das_Fatboy
Originally Posted by harleycat225
This was the response I got when I went looking for the connectors. I took pictures of my '11 and e-mailed to PCS. If anybody knows anything different please let me know...........
"Hi Chris,
The GT150 series are only device connectors i.e. sensors, switches and such – there is not male mating connector for those made by Delphi
PCS - Performance Connection Systems
PO Box 556
Marion, CT. 06444-0556
Phone: 203.440.9945
http://www.PCSconnectors.com
Registered CCR / US Government
Cage Code: 4UMU0"
I just ordered this receptacle today, it is an entire kit with male pins and wire seals included. Hopefully it will be here sometime next week. I am not sure how well it will work, or if it is a better fit than the one mentioned at the beginning of this thread, but form the looks it appears to be the correct connector....I will pass on any info once I recieve and try it out.
Ps. According to the service manual, the existing plug is a "3 Place Delphi GT 150 Sealed" for those wishing to explore it further.
  #36
Old 07-06-2011 | 04:05 PM
fernman's Avatar
fernman
A paper clip, soldering gun and shrink wrap tubing works just fine. Is is hidden, you know.
  #37
Old 07-22-2011 | 08:42 AM
dale3dale8's Avatar
dale3dale8
Stage III
I bought some too. Not even close????
  #38
Old 07-22-2011 | 09:00 AM
skratch's Avatar
skratch
Originally Posted by fleabite
Any signs of a trickle discharge from the battery with this?
~fb
all this is doing is adding an audible component to the already installed alarm system. it has no current draw associated with it. think of it like adding a speaker to your home stereo. the major difference between this and the hd siren, there is no battery back up with the radio shack system. only you can decide if that is worth the $70+ price difference.
  #39
Old 08-11-2011 | 02:02 PM
Beans HD's Avatar
Beans HD
6th Gear
skratch
So this cant drain you battery because it does not drawl any juice?
I did the install, it was straight forward, just was not sure of it killing the battery. I assumed that was why the HD siren had the battery backup.
Thanks
Rob
  #40
Old 08-11-2011 | 04:02 PM
mllgator's Avatar
mllgator
Wachuko:
Excellent Info as usual.
Used your Instructions for the RG outer fairing removal this past weekend.
Your comment re: removal of the headlight assembly was on the mark! Have no idea how long it would have taken to reinstall without you suggestion. Thanks
I am really unhappy about the degredation of the FM signal (with the hidden antennae), but stunned with the improvement of the BOOM speakers.
Thanks again
Quick Reply: Radio Shack - Alarm Siren Install - 2011 RGC
