Radio Shack - Alarm Siren Install - 2011 RGC
Old 04-23-2011 | 03:12 PM
MasterGuns(Ret)'s Avatar
MasterGuns(Ret)
I'll just throw in that two are louder than one. Solder two sirens together and put one on either side, or both on the same side. I've done it both ways, but am running both on the same side now. I had one on the the other side and linked them with some speaker wire, but it rubbed through, killed the sirens, and blew my battery fuse. I suppose if I would have run the wire correctly the first time it would have saved me some pain, but live and learn. They're both plenty loud on the same side anyway.
Old 04-23-2011 | 05:45 PM
DevilSperm's Avatar
DevilSperm
I cant thank you enough. I just did this today on my Ultra and it works perfectly. I never even thought of using a cheapie siren like this. $8.22 well spent
Old 04-24-2011 | 01:37 AM
mike5511's Avatar
mike5511
Originally Posted by iclick
FWIW, the connector for '07 is under the right side-cover. Wire colors match-up the same way as described here. I spliced into my original harness using blade connectors, leaving the original intact. The siren has been working for 2½ years now with no problems. Great $6 investment.
Blade connectors? The 07 must have a different plug than the 08. Or did you use those tap things to splice into the wires? (a picture is worth a thousand words......and my bike is ready to go but all we've had is storms this week.....idle sounds really good though.)
Old 05-31-2011 | 08:40 PM
r0ckie's Avatar
r0ckie
Hey, I got the RS siren and installed today but to wire it I just pushed the wires into the plug and then re-inserted the plug. It seems to work fine but instead of 1 warning chirp when moving the bike I get 2 or 3 before it goes steady(plenty loud too). It disarms as advertised when I bring the key fob close. I assume it's on the same frequency as the HD factory audible alarm? Did I miss something on the wiring? I'd hate to kill the battery, burn something up, etc.
Thanks again for all the help.
Old 05-31-2011 | 08:56 PM
JRBass's Avatar
JRBass
Sounds right to me. 2 warnings and then Screaming. Fob turns off the alarm itself. where you wired the siren to is controled by the TSSM(Alarm Module)
Old 05-31-2011 | 09:33 PM
wachuko's Avatar
wachuko
Cool
Yes, same here.
Old 05-31-2011 | 09:46 PM
AbnMP13's Avatar
AbnMP13
Anyone else buy those plugs? If so I'll purchase one from ya.
Old 06-01-2011 | 04:29 PM
Jack Straw's Avatar
Jack Straw
Originally Posted by dawg
Here is the link to the 3 place metri-pack connector needed that I posted on the other thread in the other forum if you want to make it look factory without having to splice and run it through the dummy connector. Have to buy pack of 10 but I'm sure you could split them/sell them with others doing this mod.
Nice write up wachuko. Just got the stuff from Radio Shack today. Couple of questions....
dawg - Do you need a delphi crimper tool in order to use that metri-pack connector?
Also, I assume pulling the main fuse is why the battery wasn't disconnected?
Any signs of a trickle discharge from the battery with this?
Thanks.
~fb
Old 06-01-2011 | 05:38 PM
harleycat225's Avatar
harleycat225
This was the response I got when I went looking for the connectors. I took pictures of my '11 and e-mailed to PCS. If anybody knows anything different please let me know...........
"Hi Chris,
The GT150 series are only device connectors i.e. sensors, switches and such – there is not male mating connector for those made by Delphi
PCS - Performance Connection Systems
PO Box 556
Marion, CT. 06444-0556
Phone: 203.440.9945
http://www.PCSconnectors.com
Registered CCR / US Government
Cage Code: 4UMU0"
Old 06-02-2011 | 10:48 AM
Jack Straw's Avatar
Jack Straw
"Hi Chris,
So, he's saying there is no correct connector for this plug? Just wondering before I go looking for one this weekend, as there are many electrical supply stores here in Vegas.
Also, if I can't find the connector, then I'll use electrical liquid tape. I've read that certain silicones aren't good for electrical connections, such as most on the market that smell like vinegar because of their drying properties.
~And yes, it might be overkill with all the questions and such, but that's how I am about my bike(s).
Quick Reply: Radio Shack - Alarm Siren Install - 2011 RGC
