Radio Shack - Alarm Siren Install - 2011 RGC
Old 12-09-2014 | 04:03 PM
LQQK_OUT's Avatar
LQQK_OUT
Is this the correct connector in the link? The reason I ask is because according to my service manual, the connector [142] is a 3-place Delphi GT 150 Sealed Connector and NOT a 3-place Delphi 150 Metri-Pack Sealed Connector. The description below mentions "metri-pack".
I've also seen other links referencing a Delphi 280 Metri-Pack sealed connector, which doesn't make any sense to me.
Originally Posted by dawg
Here is the link to the 3 place metri-pack connector needed that I posted on the other thread in the other forum if you want to make it look factory without having to splice and run it through the dummy connector.
  #162
Old 12-25-2014 | 06:18 PM
LQQK_OUT's Avatar
LQQK_OUT
The following connector (which has been mentioned in a prior post) is the correct part.
http://www.casperselectronics.com/st...oducts_id=1293
I have (3) extra Delphi 3-place GT-150 P2S (Pull 2 Seal) Male connectors left. I purchased a few of them for some friends and myself.
$20, see my classified advertisement.
https://www.hdforums.com/forum/touri...connector.html
Originally Posted by Sharpie
Anyone come up with a part number for the Delphi Connector?
  #163
Old 02-16-2015 | 09:14 PM
MikeBel's Avatar
MikeBel
Great post and tutorial! Thanks for the write-up. I just completed this tonight and it works great. Easy install. It adds a little extra security, and for $9 why not?
Can't get it to go into chirpless mode though, just like post #82 my lights go off/on too fast. If anyone figured out how to go chirpless please let me know.
  #164
Old 02-17-2015 | 06:51 AM
Cobra1's Avatar
Cobra1
I have determined that with the RS siren you can not go chirp-less. There must be some circuitry in the HD alarm that tells the computer that it is installed. I have learned to live with the chirp.
  #165
Old 02-17-2015 | 07:16 AM
MikeBel's Avatar
MikeBel
OK, thanks Cobra. That's what I was thinking. OK, chirp it is.
  #166
Old 03-29-2015 | 09:06 PM
fotiii's Avatar
fotiii
6th Gear
Installed RS siren today on my 2002 Ultra, was louder than I thought it would be. Very nice right up and pictures, thanks for all u guys do in this forum.
  #167
Old 05-01-2015 | 07:49 AM
ARHD's Avatar
ARHD
Default 2014 Ultra
My 3 wires are red, white with green stripe and black. The original directions were black siren wire to green and red siren wire to brown. What about the colors I described?
I have switched them around with no luck and even followed the directions to change the chirp/chirp less mode with no luck. I tested the siren on a 9 v
olt and it works.
I used the pins, are you pushing the pins into the back of the connecter on the bike?
  #168
Old 05-02-2015 | 07:36 AM
dwl25's Avatar
dwl25
Try the front. From the back I doubt that the pins are long enough to make contact. For now I just have the wires jammed in there but have the plug to to put on when I get a chance.
I hope this helps.
  #169
Old 05-04-2015 | 07:15 PM
ARHD's Avatar
ARHD
I hope this helps.
I guess you stripped the wires to stuff them in the front? The next you have it open would you post some pics to show what it looks like.
Thanks
  #170
Old 05-05-2015 | 06:07 PM
dwl25's Avatar
dwl25
No pics for now but I'll try to get some in the future. Yes I stripped the wires on the siren about 1/2", stuffed them in and used black electrical tape to hold them for now. I'll use the connector plug when I get some time off. Some guys have actually tinned the wire with solder to make them stiffer them stuffed them in. I didn't and it works fine for now but I knpow that the tape will eventually fail.
I hope this helps.
Quick Reply: Radio Shack - Alarm Siren Install - 2011 RGC
