Radio Shack - Alarm Siren Install - 2011 RGC
Old 02-17-2014 | 06:09 PM
Greg2012FLHTK's Avatar
Greg2012FLHTK
Originally Posted by RIPSAW
On a Softail, it's easier to pull the alarm battery on a factory alarm battery siren then pull the bike battery. Simple matter of removing couple bolts from the splash guard and unclipping it. Never tried it though with the alarm set..may set the signal lights flashing. I removed my battery alarm. Lights and bike being disabled is all I need. Thats it just to the right of the belt and the plug for battery siren in the clip just below it. Of course, I have the wheel removed here but with just the splash cover removed, it's easy to reach in from the side.
If you clip the wires or unplug the HD siren from the bike without turning on the ignition first with the alarm fob nearby the siren will go off. The battery is built in to the siren housing. I discover that the hard way. I unplugged it from my 12 Limited to move it to my 14 and it went off in my hand. Not good for the ears.
  #152
Old 02-17-2014 | 06:40 PM
lightweight bob's Avatar
lightweight bob
Default Installed two sirens - better
Originally Posted by Gliden
All done. I put two of them noise makers in there. Like you said "fits like it was designed to be in there.
Wife thinks I'm nuts but it does give me a little peace of mind that if someone got into my garage at night, I'd definitely hear them now. Thanks again.
I too installed two sirens as it sounds much better. The current draw is so low it doesn't
make an operational difference. Nice thread, photos and writeup.
  #153
Old 04-04-2014 | 04:22 PM
qcarson's Avatar
qcarson
Added the siren to my 2006 Street Glide last night. Easy install and works as described. Thanks for easy to follow instructions. Make sure you pay attention to where you put the wires (Note, the siren connection is on the right side under the ESM). My siren kept going off when I put the fuse back and I discovered that I put the black siren wire into the black wire on the connector. It should be connected to the green connector wire. Anyway, it is corrected and works as advertised.
  #154
Old 05-31-2014 | 01:37 PM
jman1115's Avatar
jman1115
Default 2014 wires are colored
Red
White with green stripe
Black
It is the one on the left side right? Plug goes into plastic with no connection.
Guess it's trial and error for this one.
  #155
Old 09-07-2014 | 01:03 PM
EMTP435's Avatar
EMTP435
Cool Easy as pie!
I snuck over to my buddy's house while he was out of town today and did this install on his '12 EG UC. Very easy!!! I didn't solder the pins (I forgot to pack the solder iron), but I did drill through the back of the false plug so the wires were very well hidden. The hardest part was fishing the wires from the siren through the plug socket!
Can't wait till he 'discovers' the mod!!! And, yes, we often do things for each other like this!
Got to do the same now on my '05 EG UC. It has the factory siren, but it's finally fried. Would scare a **** ant! But being 9 years old with 147,000 miles... I guess that's pretty good.
  #156
Old 09-09-2014 | 11:04 AM
87gtNOS's Avatar
87gtNOS
ok, so dumb question....I assume the bike had to have a factory alarm system already?
I have an 09 FLHTpolice....
  #157
Old 09-09-2014 | 11:17 AM
EMTP435's Avatar
EMTP435
Yes. Both bikes came with the factory H-D alarm system. Mine (the '05) had the old push button fob and the extra siren box on it. His (the '12) just the alarm with the proximity fob & no siren (it just flashes the turn signals and disables the starter).
  #158
Old 09-09-2014 | 11:21 AM
SBates08's Avatar
SBates08
ok, so dumb question....I assume the bike had to have a factory alarm system already? I have an 09 FLHTpolice....
Do you have a key fob? If so then you have the factory installed security system.
2010 Limited with some stuff
  #159
Old 09-09-2014 | 11:30 AM
87gtNOS's Avatar
87gtNOS
no key fob on Police....just a key to lock the column and the bags....
  #160
Old 10-01-2014 | 10:42 PM
Sharpie's Avatar
Sharpie
Anyone come up with a part number for the Delphi Connector?
Quick Reply: Radio Shack - Alarm Siren Install - 2011 RGC
