Radio Shack - Alarm Siren Install - 2011 RGC
Old 06-30-2013 | 09:08 PM
vickon's Avatar
vickon
Default Double siren...
Hello conjurski, can you please send me some pics? I have a 2013 RGC and would love to do what you did!
you can PM me.
Thanks!
Vickon
  #122
Old 08-13-2013 | 07:16 PM
jay.weber's Avatar
jay.weber
Just installed on 2011 RKC and worked perfect. Followed instructions on page 1 no problems.
  #123
Old 08-13-2013 | 07:36 PM
captbom1's Avatar
captbom1
great post...goin to store tomorrow! Thnx
  #124
Old 08-13-2013 | 07:56 PM
Rhombus's Avatar
Rhombus
Default Alarm - how long?
If the bike is disturbed and goes from chirp to full alarm mode, does it time out after a period of time?
  #125
Old 08-13-2013 | 09:03 PM
skratch's Avatar
skratch
it will stop screaming after about 30 seconds..... then if the bike is messed with again, it will start screaming again for 30 secs.....
  #126
Old 08-13-2013 | 10:37 PM
SBates08's Avatar
SBates08
Done this mod on my 2010 FLHTK and a friends 2008 FLHTCU. The alarm chirps like it should when in full alarm on both bikes but when arming and disarming it sounds like a sick cricket. What's up with that?
  #127
Old 08-25-2013 | 12:23 PM
GoofySB's Avatar
GoofySB
I got the sick cricket sound on my 2002 RK and thought maybe because it was an older bike. Never did find a solution so gave up and didn't mount it. Have also wondered if maybe I got a bum alarm, but didn't pursue that. If you resolve this be sure to post or PM me.
I have a digital volt meter, which might not show a fluctating voltage like an analog would, so I took a LED bulb from a PC that was sitting around and determined there was always a voltage present on the leads for the alarm. That's when I gave up.
  #128
Old 08-25-2013 | 12:46 PM
atretes1's Avatar
atretes1
When I had my Street Bob I installed the radio shack siren and it also had the same sound when arming or disarming. I just figured it was something that was not recognized. I eventually replaced it with the Harley siren.
  #129
Old 08-26-2013 | 11:40 AM
Watchfuliz's Avatar
Watchfuliz
Originally Posted by fernman
A paper clip, soldering gun and shrink wrap tubing works just fine. Is is hidden, you know.
That is what I did on several bikes. I think I posted that somewhere too. If you are going to solder it on anyway, just use a paper clip and some shrink wrap to keep them from touching each other. Too easy and cheap I guess.
  #130
Old 08-26-2013 | 05:11 PM
davidwruth's Avatar
davidwruth
K done that. I used crimp post connecters and flattened them with pliers and then heat shrinked the connection and heat shrinked the heat shrink
Quick Reply: Radio Shack - Alarm Siren Install - 2011 RGC
