Radio Shack - Alarm Siren Install - 2011 RGC
#111
BUT I saved 70.00 so I can live with one chirp.
#112
#113
Im trying to install on 08 SG and can't seem to get the right combo. My wires are grey/ green with black stripe / black with green stripe.
One combo trips siren even with fob present. That's the only one where the siren works. Can Anyone with experience on this bike chime in?
I just did the install on my wifes 08 a couple weeks ago. Just did it according to the directions on page 1.
Red wire from siren goes to the first (LEFT) hole in the plug.... black goes in the second hole, as shown in the picture.
If you look at the connector with the latch toward you it will look like this. If you only have 2 wires.... you are using the wrong plug. The plug will be inserted into the fuze panel in a holder (you can see the holder just behind, and above to the right of the plug in the picture)
#114
#115
The plug will be female contacts...... and I fixed the link.
And I see where you went wrong...... IT'S UNDER THE LEFT SIDE COVER
#117
#118
Thanks. I'll take another look later. I put it back together to ride to work. Another search I did seems to indicate the plug is behind the ecm and the one I was referring to was not. Would make sense why colors didn't match exactly. I appreciate the quick help.
#119
#120
Worked perfect for 2013 RG
Worked perfect for my 2013 RGC. Looked and worked exactly the same as your initial post. Two things of note: I was able to hook up two sirens, just put each red wire in one connector and each black wire in one connector, worked like a charm (or chirp) :-) and then You mentioned not to put the plug back in, but I just drilled the back of the plug hole out and thread the wires through the back of it, plugged them in to the plug and inserted the plug in, worked perfect and looks good. But thanks everyone, was super simple and the wife says its crazy loud, so perfect!
