Radio Shack - Alarm Siren Install - 2011 RGC
Old 10-03-2012 | 10:57 AM
Bullitt59's Avatar
Bullitt59
Did the install on my 2011 Ultra Classic, very easy. Problem is the siren isn't very loud. I had it go off in the driveway & the missus didn't hear it in the house, 30 feet away. Going to the US this weekend, will pick up a second one to install & double the noise.
  #92
Old 10-03-2012 | 12:28 PM
iclick's Avatar
iclick
You may need to place the siren in a location that doesn't allow the sound to be muffled. For example if the sound is blocked by a metal part of the bike it will reduce the volume, as was the case for me on the first try. I had to move mine around a bit for that reason, but now it's loud enough where I don't want to be in the garage with it if it goes off. I've also thought about adding a second alarm and wiring it in series, locating it on the other side of the bike, but I don't think it is necessary.
  #93
Old 12-15-2012 | 07:43 AM
UltraNutZ's Avatar
UltraNutZ
alarm or siren? if siren I would think it would need to be wired in parallel.
  #94
Old 12-15-2012 | 08:23 AM
mikelikesbikes's Avatar
mikelikesbikes
Subscribed.
  #95
Old 01-22-2013 | 12:36 PM
knightenforcer's Avatar
knightenforcer
Did this today, after obtaining a defective smartsiren II on ebay. I was glad that my local RS had it in stock. Got the pins as well, no soldering needed if you crimp it properly. I re-used the cap from the alarm connector and just drilled 2 holes for the pins/wires to go through, cut the top tab then snapped it close.
Must say, I was in the garage and wife was in the kitchen and kept telling me to shut it off...IT was LOUD! Thanks for posting this guys
  #96
Old 01-22-2013 | 03:25 PM
Watchfuliz's Avatar
Watchfuliz
I did this too, but I am cheap! I used a big paper clip for the post. Soldered the wires to two pieces of the paper clip, put on some heat shrink, bend the paper clip back on the heat-shrink so the pins can't short across and taped wires to plug. They can be untaped and pulled out later if you decide to buy the OEM horn.
  #97
Old 01-22-2013 | 03:43 PM
iclick's Avatar
iclick
***Deleted double-post***
  #98
Old 01-22-2013 | 03:49 PM
iclick's Avatar
iclick
Siren, and you're correct. (Just noticed your reply.)
BTW, the Radio Shack siren has been durable on my bike so far, having survived now for >4 years with no problems.
  #99
Old 01-22-2013 | 04:13 PM
Watchfuliz's Avatar
Watchfuliz
Mine has been on there for 4 years too. The one I just did was on a friends 2013 RG.
  #100
Old 01-23-2013 | 10:13 PM
RoadKinghd60's Avatar
RoadKinghd60
Installed this today on my bike works great. Thanks for the information.
My siren is a bit sick on the chirp. a short scratch noise. That's fine though.
Here are a few pics of how I did the install. I used shrink wrap on mine. I wrapped each wire to the connector and then wrapped the whole thing.
I then wrapped the connector and wires in shrink wrap. I zip tied the wires while the shrink wrap was still soft. Then I zip tied the connector.
Then I tucked the connector upside down so water can't migrate down the wires and into the connector.
CJ
Attached Thumbnails Radio Shack - Alarm Siren Install - 2011 RGC-dscn2041_zps4bcefc0e.jpg   Radio Shack - Alarm Siren Install - 2011 RGC-dscn2045_zps38c4f4d7.jpg   Radio Shack - Alarm Siren Install - 2011 RGC-dscn2071_zps3434f879.jpg
Quick Reply: Radio Shack - Alarm Siren Install - 2011 RGC
