Jiffy Stand Extension Install - 2011 RGC
![Cool](https://www.hdforums.com/forum/images/icons/icon6.gif)
Jiffy Stand Extension - Part Number 50233-00
Much better now to find the stand and to lower it and also to put it back. Initially, from looking at the photos on the web, I thought it would do nothing for helping pull it back up, not the case, works excellent both ways.
Present the part, use a center punch to mark the center and help avoid the dril bit to dance around...
![](http://forums.rennlist.com/upload/stand2_copy1.jpg)
![](http://forums.rennlist.com/upload/stand1_copy1.jpg)
Instructions tells you to drill a 1/8 hole and the go to the 1/4 drill bit... errrrr nope... I had to take small steps until I was close enough to the 1/4" bit... lost a few drill bits in the process...
![](http://forums.rennlist.com/upload/stand3_copy1.jpg)
Done!
![](http://forums.rennlist.com/upload/stand5.jpg)
![](http://forums.rennlist.com/upload/stand_and_shifter.jpg)
Here you can see what a difference this mod makes to reaching the stand. When in the up position the stock tab is so hidden that it is a pita to get to. Now with this it is very easy to reach and put down or put up.
![](http://forums.rennlist.com/upload/dsc04436sm.jpg)
In this photo it is not retracted completely due to the hydraulic jack getting in the way, but you get the idea.
![](http://forums.rennlist.com/upload/dsc04439sm.jpg)
![](http://forums.rennlist.com/upload/dsc04440sm.jpg)
![](http://forums.rennlist.com/upload/stand4.jpg)
Done!
![](http://forums.rennlist.com/upload/dsc04442sm.jpg)
