CB questions
Thx ke5rbd. I'm confused about your statement: "The PTT will cause CB to transmit even if mic is not hooked up. That is why the clicking. " - It would seem to me I would hear more after the click if it were actually transmitting (voices) - I don't get why I'd hear one (click) without the other (talking). Is there a 2-step transmitting process? - Are you saying that HIS mic could be damaged? That doesn't seem to explain why I could hear nobody on Ch. 19 when there was plenty of "clicking" sounds that appeared to be CB talk activity. Do you believe this is a defect of the CB unit to take the bike back to the dealer for warranty service? - Thanks again.
move the mic closer to you mouth. The foam should be touching your lips...
CB use
I too have had problems with the CB. One thing that really matters is the boom mic position. It has a white dot indicatimg the proper position of the mic. If this is not facing your mouth it decreases the output volume drastically. The other thing I had problems with is the seven pin plug. It is real easy to push it into the connection incorrectly. Nothing more frustating than the BOB able to talk and you not able. Oh well, she sounds better than me anyway.
Check to make sure the tiny holes on the mike (under the foam) are pointed towards your mouth. Sometimes the mike gets twisted and pointed in the direction of your windshield.
wdeertz
Audio Systems
21
04-07-2021 11:56 PM
