the 120R is Home!
Old 03-18-2011 | 10:04 AM
TXCHOP's Avatar
TXCHOP
If i lived anywhere even close to Lonewolf, i would bring it to Lonewolf!
Old 03-18-2011 | 11:29 AM
scj's Avatar
scj
Originally Posted by rideon
Harry, does the clutch slip in high gear when you roll hard into the throttle? You may have to add 3 or 4 discs to the trapp. 20 discs may be two restrictive for the 120, I believe 24 is maximum flow. My HQ 103 runs great with 20 discs but is a way smaller motor.
I ran 24 disks in my 113" with a closed end cap and could not get the flat spot out of if after 30 custom maps. An open end cap and 16 to 20 disks is probably what it will take to let the 120" breathe.
You can see the pipe in my signature I am waiting on that supposedly performs and is quiet. We'll see????
The Boarzilla was punishing my ears even with the quiet baffle but it did run well.
Old 03-18-2011 | 12:21 PM
hydrolock43's Avatar
hydrolock43
Default 120r
Probably your pipe is holding it back and causing your dip and low numbers. Do you have the 58mm and high flow injectors? You can feel the clutch if you get out on the highway and open it up in too high of gear for the speed your going. Tach will climb way faster than mph if it's pretty bad. Trying to quiet that motor down is probably going to cost you performance, 120R and quiet don't go in the same sentence. I put the Boarzilla on and it seems to run strong but it sets car alarms off around town. Not really happy about it but why buy a performance supposed race motor and expect high performance and quiet.
Old 03-18-2011 | 01:08 PM
HFS's Avatar
HFS
Well if the clutch isn't slipping, and it's not running lean or anything, I can deal with it for now. If it needs the open end cap, so be it. It will be really loud then.
I wanted torque, not HP [readulling not speed.] So I figured I'd start with this and maybe cam up later. If the Supertrapp is holding 'er back, I'll go from there.
Just with all the bad karma with clutches I've heard. Maybe I'm a hypochondriac.
I guess I gotta learn more about TTS as well. I got it to work with my MacBook prior to dropping the bike off.
Thanks for all the help guys. I appreciate it.
Old 03-18-2011 | 01:35 PM
hydrolock43
HP/Tq numbers as an overall seem to be not too far from each other with the guys running Boarzillas and other large primary pipes. Not real big gains with some of the cam changes either.
Old 03-18-2011 | 01:56 PM
OutdoorJoe's Avatar
OutdoorJoe
Originally Posted by SE120RG
I picked mine up tonight. Took it out for about 65 miles. Ran it hard at times, varied my speed, did 10 3rd gear 35 to 65 to 35 accell/decell to seat the rings although the should have been pretty well seated since the dyno added 30 miles to the bike. (haha).
30 miles added because of a dyno tune....Comon!! You cant tell me every tech in that shop didnt take it out to help seat the rings for you!!!
Old 03-18-2011 | 09:10 PM
HFS's Avatar
HFS
Well I went for a ride today, it was just to go get some oil for tomorrow's oil change.
I've been getting advice and help from a couple of great tuners. We'll get 'er all sorted.
Oh, someone asked about primary fluid - HD Formula+
Old 03-18-2011 | 10:09 PM
Eric in chicago's Avatar
Eric in chicago
Running B and M Trick Shift in with my Rivera Pro/VPC/Gold spring. 140 plus tq. Just put 900 miles on it at Bike Week. No slip. Crazy power, crazy... Be careful with the front wheel getting light when you hammer it (any gear!)
Old 03-18-2011 | 10:13 PM
sporacer's Avatar
sporacer
Here is the Dyno Sheet.
I hope it is clear enough.
With the scan I cut off the numbers, So I entered them in. I am a little disappointed in the numbers compared to Harley's Numbers of 135/135. How did they get that with a SE Clutch?
Why is everyone having clutch issues?
I've got an email into Rivera as well.
Harry
That dyno sheet looks like a too restictive pipe to me.
Old 03-18-2011 | 10:56 PM
Inspector 12's Avatar
Inspector 12
Picked my Street Bob up at Latus today. What a beast. Just a short ride today when I got home but tomorrow is looking better. Can't wait..
Quick Reply: the 120R is Home!
