Harley Davidson Garage Door Opener Kit
Just got one for 10 bucks. Will photo the install and draw a WD when I install. Going to have to gut the thing and see how it ticks. Then I will install. I am trying to think of a way to keep it out of the batwing so when you want to reprogram you don't have to rip the fairing apart. I am thinking in the side cover where the fuses are and battery off of the Aux port. That way I can use the switched signal from the Aux switch to trigger it. Not sure yet but that is the way I am steering.
HERE'S mine.
Here you go guys. Got a 10$ Chevy Home Link remote off of Ebay. The yellow/purple is ground and the yellow is +12 volts DC. Green on mine is the one to make the small LED's light up. Those were so at night you could see the switches. I dropped a small chunk of wire across the 12v supply and the green one just so I could see that I have it powered up. The next issue was finding a way to make all the switches work. I removed the old tiny switches and plugged it into a 12v supply on the bench. Stuck a meter on the small dots to see where I needed to solder the wires to. 2 wires per switch. Next one more test to be sure when you short the 2 small wires the red light turns on. After that I cut the mounting tabs off of the case and its ready for some goo. I didn't have any clear silicone around so I will do that tomorrow. I plan on just getting the wires where I need them and I will shoot it full. One to stabilize the wires and two to seal everything up from dust and vibration. Next I will program the unit and attach it under the fairing to a 12V supply(probably off of my keyed power to the radio) and then hook up 2 leads off the switch to a spare odo button I have laying around.
In the end, I will have 3 sets of 2 wires off the unit. 2 will be for activation of the door and the other 4 will be for the programming of the unit. Every time I move now or get a new door I can reprogram and good to go. All in all a cost of about 13.00$ for the unit off of Ebay. A local junk yard might even be cheaper. Not sure.
Here is a pic to see how it is set up.
This is the only page I have read that says Harley's is easy. You have to remove the tank don't you?
One day I was throwing away some warranty parts at an auto dealership. Found a sunvisor that was warrantied for a vanity bulb and ripped out the Homelink. Had no idea why I might need one, but I pulled it out today and am gonna figure out a sexy way to make it a part of my bike. I'll be able to control up to 3 garage doors for free. Cross your fingers for me. I hope I helped someone with an idea. Maybe a junkyard? Maybe you or a friend work at a dealership?
I rigged mine up like Krazy3 did by soldering two wires to the circuit board and mounting a Radio Shack switch (#275-644, $2.99) to the fairing insert cap (switch panel). The opener itself is wire-tied to the left horizontal fairing bracket under the outer fairing. It's the momentary switch on the far left, and the opener itself has endured two bikes over a period of 13 years, probably 150k miles, and still works. I've changed the 9V battery maybe three times in that period. Total cost was $3 assuming you have a spare opener.
garage door opener
For you RGU owners, here is a simple install. I ordered an extra garage door opener remote $19.99 (from 365garagedoorparts on Ebay). Added velcro type fastners (free from EZpass) and stuck it just under the radio. It cleared the bars by about a half inch. Entire "project" was less than 10 minutes. It blends in well with the black inner fairing. I got the 2 button remote and can open either door with the push of a button.
I do not solder. I did not drill my fairing. No swearing needed. If I can do it....
