Avon tire pressure
Avon tire pressure
I just had a new set of Avon Venon X's put on my 2007 Road King Custom. Man, what a difference from the stock Dunlops! I remember reading on here that the Venom's require higher air pressure than Dunlops and I called Avon's customer service to find out the recommended pressure. The guy I spoke to recommended 38 front and 44 rear for my bike. The way he came across to me on the phone was a bit less than knowledgeable so I would like to know if those pressures sound right to those of you who ride with Venom X's. I ride solo 95% of the time. Thanks.
I've had my venom's for about 2 years and here are the recommendations Avon provided at that time.
Solo: Front 38-40, Back 44
2-Up Light: Front 40-41, Back 46
2-Up Heavy: Front 42-43, Back 48-50
I ride with 40 front and back when riding solo and increase the back to 44-45 when riding 2-up.
Great Tires I run them on my machine. Heres their TP Guidelines
http://www.avonmoto.com/wp-content/u...lines_2010.pdf
Well I tried Spider's recommendation of 68 front & 83 rear and the ride was just a bit harsh. I called Avon customer service again and got a guy who seemed very knowledgeable this time. He confirmed 38 front and 44 rear. He did say I could lower it if seemed too stiff by a few pounds but no less than 36 front and 42 rear.
I had also contacted Avon when I first got a set. I have a 150 on the back of my '07 SG. I use a local Indy for my service work and he is a Racer, Florida Champion various times. He reccommends 40/40 Solo. 44 rear when two up. Never a problem. (Avon reccommended a 45/50 which I felt was too high).
I put on Venoms at 12,000 miles. I run 42 in the back and 39 in the front. I have put 11,000 miles on the tires and still measure 6/32, so he told you right, they last longer with more air than the 36 they recommend for Dunlops. I'm staying with the Venoms, great cornering and smooooooth ride
Ga Blue Knight
18
08-02-2013 06:41 PM
