Tour pak install for '09 SG
Your bike has a tour pak wiring harness, but it's used on the SG's (that have a tail light) by the tri-bar LED in the rear fender fascia. You can make a pigtail to split the tour pak harness and use it for both the tri-bar LED and tour pak lighting, wire the tour pak lights to the accessory connector under the seat, or splice the tri-bar LED light to the license plate LED wires behind the tail light as described in my lengthy post in this thread:
https://www.hdforums.com/forum/touri...ml#post4097568
Good luck with your project.
Carl
Carl
