idle issue (bit long)
Old 03-14-2011 | 02:44 PM
1931jamesw's Avatar
1931jamesw
Originally Posted by scooter1128
thanks all for your thoughts on this. what is this heat management? i mean, i heard about it on the newer bikes where you cut off the rear cyl while stopped. should the check engine light come on? or, is what happened (erratic idle/stall) caused by this, the heat management? since it was perfectly fine coming home, guess i wont worry about it. thanks again for the responses.
Im 95% certain that your bike does not have a temp management system. If you have no codes and your oil level is good, I wouldnt worry any more about it. Maybe you could install an oil cooler or run a synthethic lube or both.
Old 03-14-2011 | 02:45 PM
chevele72's Avatar
chevele72
The heat management drops the rear cylinder, as soon as you blip the throttle it comes back. It can be turned on and off (at the dealer), I forgot it was on the older bikes, though I don't remember the years. I knew on the TBW bikes it can be turned on and off with the throttle('08 up). Hope this helps.
Old 03-14-2011 | 02:52 PM
Jim Dawson's Avatar
Jim Dawson
Originally Posted by chevele72
...I knew on the TBW bikes it can be turned on and off with the throttle('08 up)...
That feature is on "late" model '08s and newer. My early '08 did not have that ability (until I upgraded my SERT to the TTS Mastertune which includes the feature).
ptl203
05-21-2014 05:44 PM
ronster2
07-04-2011 09:48 AM
CCPD
01-10-2008 06:54 AM
bryon703
05-15-2007 03:49 AM
Quick Reply: idle issue (bit long)
