how to read oil temp gauge
Thanks for the replies, I just think this is a hard gauge to read .but the vertical mark of 230 degrees is a good point of reference. so I now know why they put the white dots in it, its to confuse me! Anyway it was an easy job to install . The instructions call for cutting the two pronged connector ,I just added jumpers with spade connectors that plugged into original plug.
You are right, the HD oil gauge is baffling. The hash marks are not linear i.e. every mark does not equal 15 or 10 degrees. I figured this out the hard way, but in my opinion the gauge is intentionally deceptive. Any reasonable person would read the gauge as 230F with the needle at the 12 o'clock position, but that is not correct. The "dot" to the left of 12 o'clock represents the 230F numbering. When your needle is pointing to 12 o'clock, bisecting the printed 230 number, your temp is actually about 245F. This was my experience with the same HD gauge I installed in 2007, I validated this observation with threee seperate external thermometers, my friends bike read exactly the same. After I verified this I took the gauge to three different dealerships and asked the service guys to show me how to read it and none of them were correct, it took a parts guy to give me the right answer. Knowing the MOCO, I highly doubt they have corrected this descepancy yet, since it wont positively impact the profit margin. Don't take my word for it, get yourself a turkey fryin thermometer and check it for yourself. Just for kicks try to get someone at the dealership to explain to you the correct way to read that gauge.
The oil at the front of the oil pan where the fairing oil temp gauge reads from is substantially cooler than the oil measured from the area of the dipstick at the back of the pan. If the gauge is at 12 o'clock (= 230 at the front of the pan), then expect the oil as measured at the dipstick (rear of the pan) to be anywhere from 245 to 265. The oil guage is not a linear scale, but 230 degrees is at the 12 o'clock position.
Look at the Medallion oil temp gauge which is set to the same basic scale as the Harley gauge, 230 degrees is at 12 o'clock. http://www.medallionis.com/Bagger.html
