Tour Pak Aux Power for 2010 UC
I went install the Tour Pak Aux Power socket today. As I was going through the directions, it had a wire harness for me to route up to the aux plug near the ECM, but there is a plug in the tour pak that fits to the power socket. Is this the same plug that is used on the Ultra Limiteds? Can I use this plug or should I go with the harness that was in the box? Thanks in advance.
Haven't looked at the wiring diagram but I do ride the 2010 Limited.
If you go in the Aux socket you can control the Pak socket from the Aux switch on the front panel. If you go in to the power socket it will be an ignition live. Personally I would use the power socket option as I would rather use the Aux switch for something I need to control more regularly. I currently use it as a garage opener
