Clutch cable routing on Road King
Could you check your clutch cable routing on you Road King- does it route on the clutch side through a small metal clamp at the windshield bushing nut? Has anyone run the cable through the top of the nacelle like the throttle cables are routed? Thats how the Street Glides are routed. My (indi) mechanic says it would look better if it were routed through the nacelle but I'm not too comfortable wiht that... What do you guys think? -02 FLHRi
When I changed out my bars, I had originally run the cable through the metal clamp but I just didn't like how it looked with the cable hanging out there. So, I routed through the nacelle and now the clutch cable and brake line have the same profile as they come off the handlebars and into the nacelle.
I changed my bars to Heritage Bars, but I routed the clutch cable back like it was from the factory, through the clamp at the windshield. I want it straight as possible so It will be easier to pull. I know the newer cables are lined and don't need oiling, but I oil mine at every service with Inox cable lube. I have arthritis in my hands.
