Adjustable Backrest with Reach Seat
Is anyone using the adjustable backrest with a reach seat on 09+ Ultra or Limited? I need a backrest and like the quick adjustablility but worry it may be too tall for the reach seat. I have the reach seat and had to replace the handle strap with a much shorter one (about 6") so I'm assuming the standard seat is taller. Is this correct or is the difference in the width of the seat only.
I have the standard backrest. Adjusted it to where I was comfy, and left it like that. Put the allen wrench in my tour pack in case I felt the need to re-adjust.
TIP: If you are having problems with getting the backrest into the bracket, loosen the rear mounting tab so you can slide your hand under the seat and glide that sucker right into the bracket. This tip is very valuable if you have a stock Ultra seat.
