Brake light modules
I have the one that you wire in to the brake light. It blinks two or three times then holds steady for three seconds and repeats. I ended up taking it off. It was on the bike when I bought it and I installed the Harley led turn signals. It caused the led turn signals to blink when I hit the brakes so I removed it. It works great and does a good job. I have had people notice it and back off when I hit the brakes. Before I installed the leds I had the turn/run/brake module installed with it and it works great together.
I had the basic non-LED Back-Off that you wire in-line into the brake wire. Easy install and worked as stated. I looked at the electrical diagram, found the brake wire and wired it from the wire harness that comes up under the seat/rear fender. Then mounted the modulator under the seat. I did end up taking it off and got myself a BAL. So much better.
I can't go with the brightass lights route due to having a 2010 Street Glide and I do not have that taillight assembly.
I got the Backoff Brake Hold Module in the mail yesterday and am going to install it tonight. I'll let you guys know how it goes.
This install uses the speed sensor line and I have my service manual out now trying to figure out where I am going to tap into that wire.
If any of you know where that might be let me know.
Joe
Joe
I have the Kuryakyn pulsating one that plugs into the rear harness on my 04 FLHT. Only thing it you have to purchase the two lesnes seperately. You can get them from Custom Dynamics for like $3 a piece. I also have have my rear running light wired to operate with the brake light too.
__________________
I got the same kit, 08 RK, went to Harley to get the two red lights for less than $5.00
__________________
Has anyone completed the BACKOFF BRAKE HOLD MODULE. I found the VSS connector under the starter ('012 RGC w/ABS) and it lead near the battery box. Manufacture claims I need to put a 300-400 ohm resistor where you cut the original brake wire. I tried 300 and the brake lights stay on all the time. Any advise?
