Corbin Help
Corbin Help
I recieved my new Corbin Classic Solo seat in the mail today. The instructions say to remove the stock seat, then if you do not have a heated seat, skip to step 10.
Nowhere in the instructions are there any guidence on removing the rear seat bracket (or whatever it is).
Does anyone know what goes, and what stays on the bike toward the rear of the seat?
Thanks,
mikebaby
Thanks,
mikebaby
Take a picture. I'm not sure what bracket you're talking about. I have a classic solo on my RKC, I didn't have to remove anything, but the seat bracket for the Corbin does install on the 2 bolts sticking out of the rear fender.
Do you have a rider's backrest on your bike, by any chance? If yes, it has to be removed.
Here is a photo...
There is a bracket that attaches to the two bolts coming out of fender. The stud that is threaded is bolted in the tab at the base of your tank. You slip the back of the seat under the bracket and then drop the front of the seat onto the stud and it should click in. The key lock releases the catch to remove front first then the back.
