torque values
1. Exhaust studs - Tighten Bottom nut rear cylinder 9 - 18 in-lbs first. Tighten top nut rear cylinder to 100-120 in-lbs. Then final tighten bottom to 100-120 in-lbs.
Front exhaust is reverse order. Tighten top nut to 9-18 in-lbs, then bottom to 100-120 in-lbs then final tighten top to 100-120 in-lbs.
2. Cross over clamp to 25-30 ft-lbs.
3. Transmission flange nut 20-25 ft-lbs.
4. Nut holding crossover under the bike 14-18 ft-lbs.
5. Muffler clamps 38-43 ft-lbs
6. Muffler brackets (Two bolts at back wheel) 96-144 in-lbs
I think that's it.
I think that's it.
