Reinhart true duals exhaust gasket?
I have a 05 bagger that I had my dealer install Reinhart true duals on. At the end of last season I lost one of the gasket flange nuts so I replaced and re-torqed. Than I lost the one on the rear cylinder. I just loosened everything up and was going to replace the gasket with STOCK Harley exhaust gaskets. The gaskets are tapered but the header pipe on the Reinharts is not belled like the stock header pipe. After I installed in sure didn't seem like the header was very far into the jug. I'm going to call Reinhart but thought I would ask here if there is a differant exhaust gasket that would be better to use with the Reinhart pipe rather than the tapered gasket from Harley. It appears that as soon as the header starts to engage the gasket it stops pulling into the jug. Has anyone else run into this problem.
stevereno
Exhaust System Topics
05-23-2009 02:29 PM
