oil scavenging systems
I used the rogue system today, i was skeptical. But dam im a firm believer now! It took two of us to do the oil exchange, since i have a slightly different method of raising the bike up. But it does as advertised and u do not loose any oil pressure as long as you follow the directions. To me this is a must for sure!
I have been using the Cors System since it came out in 2006? For $20 bucks it does a great job abd removes the dirty oil in both my Sportster and Roadglide. Pop it on by the filter, aim plastic tube in oil drain pan, start engine and watch until clean oil flows, shut down engine.
My buddy designed and produces this product and offers it thru catalog s and his website.
www.2armcyclestore.com/
Tell him Leroy told you about it online. He might cut members a better price?
Leroy
Leroy
Leroy
Leroy
The Rogue system just caps off the filter and drains from the tank with an adapter.
The Cors system looks simpler to use and it's 1/5th the price.
Has anyone seen this system??
http://www.liquidvac.com/
I would not recommend it for a MC - much easier and you'll get more out by pulling the drain plug.
On the 09 and up Touring bikes, the Rogue Choppers Scavenger system uses the pipe plug which is where the oil temp sensor is installed if you mount an oil temp gauge in your fairing. So it's either scavenge the oil or check oil temp. I chose oil temp.
I can live with a few oz of old oil mixed with new oil and my engine doesn't seem to care either.
I only use top of the line oil and oil filters, which I consider more important than completely drain the crankcase and lines during an oil change.
My 0.02cts.
My 0.02cts.
catcher
Oil Archive (no new posts)
12-03-2006 11:45 AM
