Replacement idea for Broken Tour Pack Rail and Saddleback support
I am looking for an alternative to welding and replacing the oem tour pack support rail and side mounting brackets for saddle bags.
I purchased a used mount rail but noticed the two weld points on each side of each fender strut is broken as well.
I realize welding is an option and it would be better than new. However, the reason is probably overloading, and I will probably do it again.
The mounting rail is hollow tubing, and the fender strut supports the weight of saddlebags and the exhaust system as well. Quite an undertaking for such limited parts, I would think. I was wondering if anybody has machined a new part or know of a better solution.
Thank you Randy
Thank you Randy
Thank you Randy
Thank you Randy
roadking71865
Screamin Eagle CVO Models
06-05-2010 10:39 AM
