Clearview windshield for roadglide, any using one?
Stock Windshield is a little tall for my taste, clearview has a 1inch under, that sounds good, comes with new not falling out rubber piece and new well nuts, anybody using one of these, the model is GT-Small? Not interested in those cheap shields, got a 10" smoke and its ok, but its thinner than stock so no way the rubber gasket is going to stay on and the holes are bigger so the washers slip thru.
RE: Clearview windshield for roadglide, any using one?
Gunrunner,
I have the Clearview 9" tinted on my RG. It is very high quality, thicker than stock and the well nuts are a big improvement over stock. I also have the Euro-Lip on mine. The lip supposedly adds 2" of air lift so the 9" acts like an 11" plus it just looks good. I have the stock shield, the HD short opaque black and the Clearview. I run the Clearview all the time. It gives me just the right amount of protection and I still get the wind in the hair and the look I like....not the hair, the bike!!
I would buy a Clearview again without hesitation.
RJ
RJ
Agree! I run the GT Medium and it is perfect for my line-of-sight.....2" over. Excellent quality. The well nuts they provide didn't seem any different than the ones HD uses.....both fine. My only option was the smoke tint.....and I believe the flare at the top of the shield is part of the design, not an option.
Good people, good service, great product. Im most pleased with mine.
Not sure about the roadking. but stock hieght for newer roadglides is 16.5 total, or 15&3/4 measured from top center to center of middle mount hole. Just ordered the Gt-small, grey tint, the top recurve shape is standard on all clearviews, this is said by John to be line of sight 1 inch lower than stock, and its a little longer on the sides and slopes back more than stock, 3 weeks est of delivery, but im sure it will be worth it.
Gunrunner - I believe we have the same bike, 07 pewter pearl roadglide. I have the GT small tinted on my bike. For me it works great and the color of the shield looks great on the pewter pearl. I'm 6'4' and the shield gives me just the right combination of view over the shield and the wind protection is either equal or better than stock shield.
I should also mention that I don't use the stock RG seat. I find that it sits me to high up and pushes me to close up front. I use the Harley Rallyrunner seat which sits me lower and further away. For my height it works perfect with the GT tinted small Clearview.
Check my sig for a pic of mine. Mine is +2" and clear, non-vented. Clearview will ask your height & inseam and make a recommendation as to what size you need. They are fabulous to work with. The only negative I have is that the shield is wider than stock (a good thing, since I'm wider than stock too) and my mirror stems contact the side of the shield when turned all the way to the stops.
BG Weasel - I had the same issue with the mirror stem. With me it was because I had originaly pushed my handle bars a little further forward due to long arms. I fixed just by slightly adjusting the handlebars a little closer to me until the stems don't touch when fully turned in the locked position.
