Cornfused
Cornfused
Ok simple although I understand less heat with no cat that being said does a stage 1 have to have new header 2 1 2 which means no cat or can you leave the cat and just get A/C and PCV????? I already have Jackpot 4" slips on my 2011 103 SG...... I know I've read about this b4 but CRS has ahold of my brain
All Stage 1 does is add a less restricted HD air cleaner and raise the RPM limit to 6200 RPM. It does nothing to the fuel management system. Harley can not make any changes to the fuel management due to EPA regulations. You can add aftermarket exhaust and an upgraded A/C without changing the fuel management system. The computer will make adjustments accounting for the increased air flow and adjust accordingly and keep everything in the very lean, very hot EPA F/A ratios.
I would look at a K&N AC and the new non EPA TTS (old HD race Tuner) fuel managment system.
So you are saying that a stage 1 is an air cleaner and a rev extender, and that the OEM ECM is intuitive and capable of compensating for an air cleaner and exhaust change. Those 2011s have come a long way. In 2006 a stage 1 was defined as a less restrictive air cleaner, free flowing exhaust, and a tuning device of some sort. Guess I need to pay attention to the changing world around me.
BKSinAZ
04-08-2016 12:25 PM
