Posted in Exhaust and no response
Old 03-04-2011 | 09:25 PM
Nightglidr's Avatar
Nightglidr
Damn, I was going to answer you then I got distracted by Garcou's Avatar......
What was the question again?
Old 03-04-2011 | 09:49 PM
Bluehighways's Avatar
Bluehighways
I have never used anti-seize on any exhaust nuts, bolts, whatever and I've probably built a few thousand engines in my time.
I quoteth from the official HD 2010 Service Manual for my 2010 Heritage:
  1. Install upper nut and tighten finger tight
  2. Install lower nut and tighten to 9-18 Inch Pounds
  3. Tighten Upper Nut to 100-120 Inch Pounds
  4. Tighten Lower Nut to 100-120 Inch Pounds
Thou shalt not under tighten, nor shouldest thou over-tighten the wholey Harley-Davidson Exhuast Nuts, nor shall ye apply any anti-seize or oil to the apointed fasteners . . . so sayeth the good book from Milwaukee of Wisconsin . . .
Old 03-09-2011 | 05:58 AM
Rickr01's Avatar
Rickr01
Thanks, LMAO.....
Old 03-09-2011 | 06:06 AM
Iceman24's Avatar
Iceman24
Anti-sieze and torque 1st nut lightly (60-80 in/lb) and then the other to spec (120 in/lb) & then finish 1st to 120 in/lb...repeat for other cyl. This allows the gasket to form properly. Also, remember to re-torque after 50-miles.
jokenroll
Shovelhead
10-20-2014 03:00 PM
Rickr01
02-23-2012 11:49 AM
craigffb
08-17-2010 02:43 PM
flhs84
Flathead
03-06-2010 03:56 PM
Sniper318
01-24-2010 12:30 PM
Quick Reply: Posted in Exhaust and no response
