The "Tick" is in the tuning!!!
rebuilt my top end this winter and had a loud tick like the op,worce when warmed up, used the tts tuner and also got some help.
researched this tick,loud drivetrain stuff a bit,was assured id tuned it right,read also it can get quiter but I didnt want to wait.
came to the conclusion I could go in two directions(actually three"live with it")
1)hand it over to a good dyno tech....$4,5,6..hundred
2)try the HQ black ops lifters....$180
So I replaced my (new this winter) stock lifters with the Head Quarters an WOW WTF tick gone! engine purrrrrs.. hot.. cold.. all rpm's
just my 2 cents worth
go to page/post 1989'ish on the tts mastertune thread under ignition section on this forum,,,thats where i got that final map to enter in from mr wizard.He told me to use it on my final map
head quarters says the bleeddown rate is slower and the percision is higher then the stock lifters. my new stocker lifters were fine when i through them out and replaced with the ops.You could hear a symetrical tap as the lifters slipped off the ramps of my 259 cams with the stock ones??. I dont know what the hell im saying but it worked!
Thanks for the information. I may give these lifters a try
is that good or bad?
I set a few things to zero ,ran a vtune a few times,set my zero'ed out stuff back and then changed each afr block as per mr wizards map then loaded this as my final calibration in a nutshell. bike ran great very happy right off the bat,but this loud tick was there the whole time util using better lifters.
I prefer open loop operation cause it eleminates the o2 sensors. The narrow band o2 sensors only switch back and forth and are not that accurate so i just turned them off by getting out of the 14.6:1 ratio setting. The o2 sensors are also ment to work with 100% gasoline and due to the fact we are now using 15% ethanol this is where most of us are getting our tuning issues. I assumed that 10% ethanol mixture was already taken into consideration with the SEPST software but it was not you have to change you settings to include the ethanol percentages. I did some digging around and learned that at 10% Ethanol, the Stoichiometric Ratio is actually 14.3:1 and anything higher than that is too lean. I also learned that the 2010 and later models are running 14.4:1 with the cat. So now that we are adding another 5% ethanol to the fuel for a total of 15%(sometimes higher due to contamination) the ratio requirements that are needed makes the A/F ratio even lower like around 14.1:1. Iclick mentioned that this sound could be spark knock, at first I was not sure about this but coming across this new information I think there is some validity to that statement. I just hate increasing my A/F ratios as the fuel prices are climbing and dont want to loose performance by retarding my timing so...
