Power Duals - Fitting Advice Wanted
would be great to see some photos as u do the removal and install.. will be doing mine mid June sometime.
When you finalize the position of the heat shields, make sure your brake pedal lever won't touch the shield during full-on application of the brakes. Otherwise you'll have to reposition everything after you feel this weird vibration during your first ride. Minor, but worth a mention.
Ok, easy answer to your exhaust-to-cylinder head torque. 100-120 inch pounds.
HOWEVER; per the manual
for the front cylinder>
Tighten top nut of front cylinder exh. flange to 9-18 in/lb., Tighten bottom nut to 100-120 in/lb., Final tighten the top nut to 100-120 in/lb.
for the rear cylinder>
Tighten the bottom nut of rear cylinder exh. flange to 9-18 in/lb, Tighten top nut to 100-120 in/lb., Final tighten bottom nut to 100-120 in/lb.
I didn't list the other torque specs for the OE pieces you aren't using because V&H (if I remember) has their own specs for their pieces.
Heat shield worm clamps should be about 20-40 in/lb. (those are OE specs)
Muffler-to-saddlebag brackets are 96-144 in/lb. (OE spec)
Muffler clamps are 38-43 ft/lb. (OE spec)
Hope that helps.
Hope that helps.
OK so began installation today, or rather dismantling, old headers removed ready for Phase 2.
Papifun : Photos have been taken, when completed I will post with any areas that caused any pain.
Da Butcher: Thanks for the advice and Torque details, quick question regarding the exhaust manifold nut behind the A frame, I removed it using a spanner as the socket set will not fit, so how did you manage to set the torque when fitting on this particular nut?
Received 5,268 Likes
