High Altitude - Lower Octane Gas?
Old 03-01-2011, 12:08 AM
Tek74's Avatar
Tek74
Tek74 is offline
Default High Altitude - Lower Octane Gas?
I'm originally from California where 87 octane is the lowest octane gas you really see at gas stations. Common octanes available were 87/89/91. The 1st time I traveled to a higher altitude state, I saw 85 octane gas for the first time. I'm in Colorado (5500 ft) and normally run 85 in my Chevy trailblazer without issue.
I've always run 91 octane in my motorcycles, regardless of where I was, but my question is.....does anyone living in a higher altitude state regularly run 89 octane gas in their Harley without pinging? I'm tempted to try a gallon or two on an empty tank and see what happens, but wanted some 1st hand opinions first.
Old 03-01-2011, 12:24 AM
lh4x4's Avatar
lh4x4
lh4x4 is offline
I run my 010 Ultra at sea level with no pinging on 89 on my trip to the Keys last summer. That is all that I use. I have helped by installing an oil cooler and a Cobra Fi2000r fuel programmer. I run three bikes with the TC96 motor and they all use 89 octane. The air temperature was 100 to 105 for the entire trip.
When I go to over 6,000 feet, I use 85 octane which helps the bike to run better.
HD recommends 91 which is different from requires 91. Why? The Federal government "requires" that engines be able to run on 87 octane. They are even in the process of requiring airplanes to run 87.
When you run lower octane just shift at a higher rpm and do not lug the motor. Pinging is more in the control of the operator than the ECM.
I have run 85 octane in the mountains with a Buell Ulysses with high compression without any issue going through the Canadian Rockies.
The lower the gear the less likely pinging occurs. Twist the throttle in 6th gear going 60 yes you will have a problem. But a knowledgeable rider would not do that.
I run 89 in my Corvettes and Viper without issue also.
M Oclaf (08-06-2023)
Old 03-01-2011, 12:27 AM
Tek74's Avatar
Tek74
Tek74 is offline
Good to hear....especially with gas prices rising again.
Old 03-01-2011, 05:21 AM
NoCoLoco's Avatar
NoCoLoco
NoCoLoco is offline
Spend the extra buck and fill it with premium, your bike is worth it.
Old 03-01-2011, 05:37 AM
shortride's Avatar
shortride
shortride is offline
When I rode to Colorado in 2005 on my '03 Ultra Classic I used 91-93 octane fuel until I got to Colorado where 85 was all I could find in Colorado Springs. The bike seem to run fine until I got to Denver where it it didn't want to stay running at idle speed at stops. It also didn't seem to have the power at the higher altitude.
Old 03-01-2011, 07:22 AM
blusmbl's Avatar
blusmbl
blusmbl is offline
That wasn't a result of the fuel. You lose about 25% of your power at Denver altitude due to the loss of oxygen in the atmosphere.
You can get away with lower octanes at altitude because of the lower cylinder pressure. I wouldn't be too afraid of backing it down one octane grade, but I'd also log data with a calibration tool to be safe.
The following 2 users liked this post by blusmbl:
deadhawg (08-06-2023), M Oclaf (08-06-2023)
Old 03-01-2011, 07:25 AM
nvsteve's Avatar
nvsteve
nvsteve is offline
I live at 4500' and regularly ride to 9000' and higher. Yes, you can easily get away with running lower octane. I did an experiment a few years back and basically found that lower octane performed just as well. For the difference in cost tho, I run 91 which is the best I can get.
Old 03-01-2011, 09:04 AM
fireaxxe's Avatar
fireaxxe
fireaxxe is offline
It can be done, the right way to do it is to tune the ECM. If you want to run lower octane you must cool the bike down (oil cooler fans and such), then you need to take a few degrees of timing out of the ignition. You will get less power and use a little more fuel, but a stock HD should not be run on lower octane with the exception of higher elevations not only do you loose oxygen which allows for a cooler burn you loose atmospheric pressure and this lowers you compression a little bit.
Old 03-01-2011, 09:38 AM
roadking2000's Avatar
roadking2000
roadking2000 is offline
Not in my bikes. Why do you even want to try it? You would be saving maybe a dollar per tank at best.
Old 03-01-2011, 10:33 AM
hoethree's Avatar
hoethree
hoethree is offline
Here in New Mexico its damned hard to find anything over 90. The "experts" say this is fine due to higher altitudes. What do I know, I majored in Business Admin.
Quick Reply: High Altitude - Lower Octane Gas?
