cruise control not working
Old 03-23-2011, 08:08 AM
capstone's Avatar
capstone
capstone is offline
Still struggling with mine. Both front and rear brake work, no issues there. I saw in the manual the test using the meter like Bill03E describes but wouldn't disconnecting the roll-off switch also tell you if that part was bad? That's how I tested it but will go back and check for continuity.
Old 03-23-2011, 08:29 AM
dirtdobber's Avatar
dirtdobber
dirtdobber is offline
The roll off switch does nothing but turn the cc off when you roll the throttle forward. you can disconnect 1 of the wires it is disabled and nothing else will be effected.
Go back to where it worked. Say it started after working the carb, that's where I would start.
Some times things do unexpected things. A friend replace his battery and now his bag/trunk locks do not work.
Old 03-23-2011, 08:35 AM
beary's Avatar
beary
beary is offline
If your roll off plug is disconnected and your cruise isn't working, then your problem is somewhere else. If you have a manual, the electrical schematics are pretty good about showing you where to look.
Beary
Old 03-23-2011, 02:18 PM
Bill03E's Avatar
Bill03E
Bill03E is offline
Just got mine working, the roll off switch was causing it, I didn't have the "lash" setup right, works fine now.
Old 03-23-2011, 02:35 PM
scoobs's Avatar
scoobs
scoobs is offline
When i changed bars on my Roadking I had the problem of the cruise kicking out on its own...ended up being that even tho I was setting cable lash by the book, it seemed too tight. Slightly loosened the lash and the kickouts went away. Was probably messing up the roll off switch..
gtrplyr
09-22-2011 11:32 PM
Cohiba_Joe
09-13-2009 07:52 PM
cardoctor
05-12-2009 08:53 PM
HEMSPLT
07-07-2008 11:50 AM
voodoodrug
12-16-2006 09:12 PM
Quick Reply: cruise control not working
